Re: I think I still have a problem with my Hydraulic pump
Posted by Idaho Ron on August 17, 2008 at 08:18:02 from (208.98.173.2):
In Reply to: I think I still have a problem with my Hydraulic pump posted by DOZER GUY on August 16, 2008 at 21:45:52:
Janicholson said: (quoted from post at 15:50:01 08/17/08) If it is an "O"ring seal the housing usually needs to be machined larger at the location of the seal to allow the sleeve to enter. Tough to machine with it together. If it is a Lip type seal, it is easy, and requires no disassembly. The speedy sleeve will not fit through the end bushing of the pump, so be sure to figure that into the repair when planning reassembly. JimN
The wooster pump is a lip seal.
I guess I am not following, sorry. The speedy sleeve does not require disassembly. So can I take the pump off remove the gear and slide the speeedy sleeve onto the shaft and into the lip seal? Here is a picture of the parts diagram. Ron
third party image
