Posted by Janicholson on August 17, 2008 at 17:58:54 from (66.173.50.119):
In Reply to: Totally Baffeled posted by Rusty R on August 17, 2008 at 17:44:38:
With it running, watch the amp gauge closely, and turn on the lights (assumes changing to 12v lamps!!!!). If it flickers for an instant, the battery is being charged, and all is well. Check the charging voltage across the battery, it should be 14.2 to 14.5 Volts. at 3/4 throttle. If around 12.6, it is not charging. JimN
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the
... [Read Article]
Latest Ad:
[More Ads]
