Re: International blade
Posted by Weldon K on August 17, 2008 at 18:27:55 from (98.16.17.188):
In Reply to: International blade posted by rustin on August 17, 2008 at 09:27:02:
Does it have a model number decal on it ? I have an IH loader brochure from 1979 and 1984 that have photos of IH 3pt blades . Photos show the decal is located on the brace angled downward from the top 3pt mast to the frame member where lower 3pt lift pins are . Models numbers 15, 20, 30, 40, 50. Blade model 40 weighs 790 lbs., model 50 weighs 1300 lbs.
