Re: F-20 Starter set up
Posted by Old-F20 on August 17, 2008 at 18:59:51 from (71.7.98.117):
In Reply to: F-20 Starter set up posted by spencer13cat on August 17, 2008 at 18:34:19:
i assume your missing the starter???
if so, find one for a 30-34 chevrolet car, its the same starter. as far as i know, no other starter will fit. H's amd M's are automatically out of the questions sine they mount to the rear of the flywheel, they would spin the wrong way if put in front like the F-20 needs.
if there are damaged teeth on your flywheel, an M ring gear will work.
generators were usually only had when lights were used. ive knocked lots in the head that only had the starter setup with no generator and no lights.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
