Re: Totally Baffeled
Posted by Wayne in MN on August 17, 2008 at 20:48:04 from (68.119.27.241):
In Reply to: Totally Baffeled posted by Rusty R on August 17, 2008 at 17:44:38:
You can get a smaller pulley on the alternator or find a better repair shop that will supply you with an alternator that does not require such a high "kick-in" speed.
I put a single wire Delco on my neighbor's 1940 H and it will start charging at about 60% throttle. My son's M works the same way, also.
Buy quality parts and the result will be satisfactory.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
