Re: IH 2606
Posted by Randy in NE on August 18, 2008 at 04:39:48 from (204.124.193.191):
In Reply to: IH 2606 posted by horsters on August 18, 2008 at 03:37:02:
Is this a gas or diesel? Have you pulled the gas line off at the inlet to the carb? You should have a solid stream of gas there. Not sure if this one has a screen on the inlet of the carb. Check that. Does the coil get hot? After 10 minutes you should be able to hold your hand on the coil. Is the inlet screen to the settling bowl plugged? Just a couple of things if it is a gasser.
