Posted by spencer13cat on August 18, 2008 at 15:11:57 from (75.12.158.180):
In Reply to: F-20 Fly wheel help posted by dave guest on August 16, 2008 at 20:46:44:
For future reference to newbie's.............................I used a similar set up. I used channel iron drilled 2 holes in one 8 1/4" on center and 1 hole in the other identicle to yours. I bought 3 grade eight bolts. The bolts are 5/8"-11 x 6" adjust your length based on cross barr thickness. Be sure to engage several threads before you put any torque on the set up. I put anti-seize on the threads and the washers where the bolts heads contact to prevent heat build up. As the fly wheel pulls off I had to re-adjust adding shims. After the few few turns I could finish pulling by using two of the bolts alternated about a turn at a time. Threaded rod would illiminate this but it is nowhere near grade eight in strength. The flywheel ends up almost flush with the bell housing before it is free. Depending on where you do this be careful. the standard F-20 flywheel weighs exactly 100lbs. Not a guess, I weighed it.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
