I have a 300u and I think some of the components are the same. I think the best place to start for these hydraulics is on your knees! Then, with a lot of good advice from this site you can have success. I guess the first thing I would do is test the PSI at the safety block. Mine is right at 1,300# PSI. That will tell you which way to look, if you don't have good pressure, I would check the screen in the safety block, if that doesn't do it, check the screen in the reservoir (I assume a 460 has a screen there also), then the safety block itself and maybe the pump. If you have good pressure, then could be leakage in your control valve. To isolate, you could put a T in after your control valve and test there. Hope I haven't given you any bad advise, but that is what I would do to get an idea where the problem is.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
