need help on 560d injectors
Posted by arkie on August 18, 2008 at 15:53:39 from (69.29.148.71):
I'm trying to get my 560d running after a rebuild.I've pull started it but I have fuel coming from injector nozzles and the injectors in the head.I put new washers and o-rings in from the rebuild kit.I pulled the injectors but not the cone below it.I've been told the pump may be out of time.That is possible as the timing mark on the pump is dang near non-existant.Any ideas how to time it without the mark?Also valve lash is set at.027 cold.Any info is greatly appreciated.ARKIE
