Re: Re: Re: Put on your thinkin' caps.
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by robbie on March 20, 2000 at 11:07:05 from (208.15.96.149):
In Reply to: Re: Re: Put on your thinkin' caps. posted by Red Man on March 20, 2000 at 06:57:08:
Sounds like you could do it. In fact, I like the idea. Take the lift brackets if it is a 3 point and turn them around. Then look at the gearbox. can you swap it around the other direction? Yazoo and Deere make mowers like this. Most I have seen have single rear wheels to get close to trees and such.Depending on what gears the mower has, Straight cut gears can be ran opposite with no damage.
Sounds like a good winter project but winter was over yesterday!
Post A Followup
: Re: Re: Re: Re: Put on your thinkin' caps.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
