Re: farmall 460 gas hydraulic problems
Posted by the tractor vet on August 18, 2008 at 18:24:03 from (76.212.239.80):
In Reply to: farmall 460 gas hydraulic problems posted by farmall fever on August 18, 2008 at 08:43:08:
Well first off even if the 460's hyd . system is 100 % she is a good but shy of having enough hyd. pressure to lift a 470 . They will lift a 370 with a 3x8 cyl but to lift a 470 you would need a 5 inch at least . Now to get it to lift it you would have to get that system up to 1750 . Get a good hyd . pressure gauge that is good to 3000 PSI . and see just what your system is putting out . should be around 1250 just not enough for bigger equipment.
