Re: 1066 power steering
Posted by the tractor vet on August 18, 2008 at 18:30:44 from (76.212.239.80):
In Reply to: 1066 power steering posted by cobra1379 on August 18, 2008 at 11:11:58:
Ya may have a leaking sump check plug , ya may have a air leak where the range transmission and the speed transmission come together , ya may have a small hair line crack in the suction tube where the tube mounting tab is , ya may be running both tractors to low on hyd oil. Try assing and extra three gallon to them and see if this helps. And like saind below she may be in need of a MCV rebuild and new pump.. And and other thought when ya changed the hyd. filter the ladt time did ya replace the O/Ring on the hyd filter ??????
