Chad: Your quite right, a full set of cultivators will weigh more than 200#. In fact my modified tool bar cultivators are probably closer to 400#. The 1000 loader had it's front support fasten to the cultivator mount. It was supposed to lift 500#, and loader probably excerted another 200# on that attachment.
As I said in my earlier post put the weight just about anywhere that suits, as long as it's bolted to cast and can't bounce in relation to tractor. There has been far more damage done to these little tractors having front end bouncing off the ground, than having a bit of weight up front.
I broke one final drive caused by corked ice chains. I've seen broken spindles, and spindle housings broke from bouncing front end. I've seen front of engine block broken from towing by front axle and letting tow chain come loose, then hitting it with a jerk. Other than that, every casting I've ever seen broken on a tractor was caused by casting being loose where it bolts to rest of tractor. Folks will say torque tubes are weak points. I've seen about a dozen broken torque tubes in my lifetime, various sizes of tractors, and without question everyone of them had been loose.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
