Re: Questioning Hydraulics on 69 Int'l Hydro 544
Posted by formerly ny bill on August 18, 2008 at 19:17:28 from (66.24.240.172):
In Reply to: Questioning Hydraulics on 69 Int'l Hydro 544 posted by Indy on August 18, 2008 at 09:45:37:
to test a hydro:
in low range, lever in the blue zone, maybe half throttle, the hydro should overpower the brakes. (the tree might be considered as better than the brakes.) in high range, same settings, hold the brakes and the tractor should stall. from your description of pushing against the tree, it sounds like the hydro is ok. a weak hydro would whine against a load like a standing good sized tree.
as to the bucket's behavior, i would expect slow response at idle. lack of lift capacity should be a function of the relief valve on the hydraulic system, not the hydro. hth.
