Re: replacing engine bearing on H
Posted by MN Scott on August 18, 2008 at 19:47:24 from (206.9.216.43):
In Reply to: Re: replacing engine bearing on H posted by Joe Henry on August 18, 2008 at 10:28:22:
I recently restored a Super H with the same problem, spun rod bearing. Some shade tree mechanic had installed new pistons, sleeves, rod bearings. He put .004 bearings on a standard crank. You can tell by the oil being burnt away that is has been run a little to long. I guarantee that the crank is ungrindable. You can have it built up by welding then grinding but that is spendy. An good H crank is easy to find. I bought one from Wengers completely rebuilt with new bearings included for around $350. The rod is junk to. Find a used one and have it reconditioned with the other ones and you will be good to go. By the way find out what caused the oil starvation problem in the first place so it does not happen again.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
