On a 12 volt tractor YES you can EITHER use a full true 12 volt coil (NO Ballast required) or else a 6 volt coil with a voltage reducing (12 to 6) external series Ballast Resistor. A full true 12 volt coil dont require any ballast on a 12 volt system and has a priamry resistance in the neighborhood of 2.5 to 3.5 or so ohms. Theres nothing else required in the ignition priamry system wiring if its a 12 volt coil on a 12 volt system.
Yous sure the voltage reducing ballast resistor was wired correct in series with the coil after the switch and ahead of the coil??? If it were a good ballast (ohms around 1.5 to 2) and was wired correct it should have reduced the current and voltage on a 6 volt coil so it will work and not burn up???
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
