Re: Question about 12 volt conversion on a M
Posted by Janicholson on August 20, 2008 at 06:21:43 from (199.17.6.122):
In Reply to: Question about 12 volt conversion on a M posted by Big Chuck on August 19, 2008 at 16:51:26:
My only thought is that You might have purchased an elecrtonic device to use 6volt accessories on a 12v system. It would be a box like thing with several wires. If so it will not power a coil. There is drastic electrical "noise" in that application that will toast the electronics in the device. Ignore the above if it was a ballast resistor as indicated below.
The use of a sensitive meter on a ballast resistor under no load can also show full system volts (12) when in fact it will drop the volts once it is placed in the circuit. JimN
