Posted by Janicholson on August 20, 2008 at 06:33:13 from (199.17.6.122):
In Reply to: Re: update posted by dianah on August 20, 2008 at 03:58:33:
Some little things are really big issues when known, and fixed.. Thanks for the update.
The rear axle seal leak will continue until the axle seal is replaced. The level in the trans should be about one finger joint below the plug to be both safe, and not leak much. I think I would live with it. If the oil leak at the square hole with missing plate is also tranny fluid, and not seaping from an external gasket, the seal in the torque tube requires a split of the tractor. If it is an external gasket, I would tighten the trans to torque tube bolts first to see if it will stop, or slow down. If not it also requires a split. (I would again live with it, unless it is drastic). JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
