Re: H hydraulics off belt pulley
Posted by old on August 20, 2008 at 17:04:09 from (4.244.186.174):
In Reply to: H hydraulics off belt pulley posted by Scott Rukke on August 20, 2008 at 16:43:50:
Depends on which belt your talking about. If you talking the flat belt pulley no because it stops when you push the clutch in so it would not be live. The fan belt yes if you can find a belt drive type hyd. pump or you can also rig up a power steering pump off a truck and they do ok BTDT on a B at one time to lift a sickle mower I built to fit on it under the belly
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
