Re: Hugh, got a question (or two)
Posted by Hugh MacKay on August 20, 2008 at 18:33:55 from (209.226.247.113):
In Reply to: Re: Hugh, got a question (or two) posted by dianah on August 20, 2008 at 17:49:49:
Diana: Tremendous amounts of water can enter the transmission, via the gear shift lever. Some tractors were much worse than others. Often if they are left in reverse, 2nd or 4th in the 5 speed and 1st and 3rd in the 4 speed water can run along hood, down the dash to shift lever. Wind can have a major effect. Optional hydraulic plumbing and valves can deflect a lot of water.
This is why gear shift lever is much worse than exhaust. In an open field, exhaust has no deflections other than updraft created by engine hood. That updraft takes much of the rain right over the tractor. Gear shift lever on the other hand, is prone to many deflections above it. Even the fenders on a Utility can deflect a lot of water, via the wind.
