Re: 3 questions about my IH
Posted by Armand Tatro on August 20, 2008 at 19:13:41 from (98.227.135.78):
In Reply to: 3 questions about my IH posted by AJ Clark on August 20, 2008 at 09:22:23:
Biggest problem with under-slung mufflers is that on a foggy day with no air movement and no tractor movement(digging with a gas engine backhoe) I got a very bad sick headach from exhaust fumes. The next day I built an out-side the frame stack and never got sick from that problem again. I will take my chances with the tree brances!!! Armand
