Posted by the tractor vet on August 20, 2008 at 19:48:09 from (75.19.120.126):
In Reply to: 1466 pto posted by cobra1379 on August 20, 2008 at 19:30:19:
Well there is no hyd. passages for the PTO from the main Hyd. system as the PTO has it's owen pump . SOOOooo my guess is (1) ya banged the pickup tube on the PTO when ya either removed it or when ya put it back in and now it lost it's seal or (2) the tiny little pin in the PTO valve stem has broken and this is now working the valve and thus the PTO will not work . SO be fore ya drain out all the oil and pull the PTo unit first remove the valveout the bottom as tis is the only way that the WHOLE valve will come out and see if you have one long valve or a two pice valve if the latter then the pin is broke and you will need to pay a visit to your friendly Case I H store and get a new pin and a couple O/Rings . Then ya need the special test fitting to hook up a gauge that will read 600 lbs. and set the pressure at 265 and lock the top nut and your good to go. Now if the valve is NOT the problem then time to pull the unit and see if ya banged the pick up tube and it is loose in it's bracket and repair and replace the seal.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
