Re: Farmall 140 leaking gear oil
Posted by Hugh MacKay on August 21, 2008 at 02:27:30 from (216.208.58.149):
In Reply to: Re: Farmall 140 leaking gear oil posted by PaulNnc on August 20, 2008 at 19:26:43:
Paul: Did you read what I told Diana about her 350 Utility. All IH tractors with that on top gear shift lever are prone to water getting in transmission.
The 140 transmission only holds 5 quarts. Before you start stripping tractor to change seals, bring it to the proper level, in may stop leaking. It's a big job changing those seals, all I'm suggesting is do the easy fix first. I can tell you, if you replace seals, and continue to run it over full it will still leak.
The brake asjustment is quite simple, length of activation pull rod from pedal to final drive housing. That will not cure it if you have a broken brake band. Final drive must come off to change brake band.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
