Re: Famall 460 utility power steering problems
Posted by Butch WI on August 21, 2008 at 03:26:44 from (69.179.90.225):
In Reply to: Famall 460 utility power steering problems posted by ihfarms on August 20, 2008 at 21:19:29:
Hello Leon,
When I first got my 460u it steered terribly hard. First I changed the hyd oil and filter, that helped a little ( I think it was a little low on fluid then too.) But the thing that made the most difference was I took the nut off the spindles and pulled the spindles right out. There was a large amount of grease/dirt inside. I cleaned them out with diesel fuel, made sure that the grease zerks functioned, greased the spindles and put them back together. It steered almost like new when I was finished. I only wish I would have replaced the Brass bushings inside the spindles when I had them apart. I hope this helps your problem! I eventually put a new hyd pump in also but that didn't really make any difference for the steering.
Good Luck!!!
Butch
