Re: 450 ignition timming
Posted by Janicholson on August 21, 2008 at 06:50:34 from (199.17.6.122):
In Reply to: 450 ignition timming posted by lbm on August 20, 2008 at 18:59:15:
Static timing (non running) should use the last mark in the direction of rotation. TDC.
It is TDC on compression 50% of the time. 4stroke has the end of exhaust and beginning of intake on TDC as well. Put your thumb in the #1 plug hole and crank/move the engine till it starts to blow air out the hole (compression stroke) If timed on the exhaust stroke it will be 180 off. JimN
