Re: smdta casting codes?
Posted by D Slater on August 21, 2008 at 09:36:52 from (72.65.150.205):
In Reply to: smdta casting codes? posted by new IH owner on August 21, 2008 at 08:50:45:
All numbers fit a SMDTA. Front bolster may be changed sometime, usually date code on the front bolster is located on right side as sitting on seat on Y post behind grill. Bolster probably has a casting # near top front center of 9131 DA or DB or DC for a MD or SMD which would work on your tractor and not have the squared corners with hole. Most all MTA have Z codes, have saw some Y codes mostly transmission top covers, brake housings and axle housings. One or 2 on transmission. Most with your serial # had all Z codes except transmission cover may not.
