Re: Differential Lock on 1969 Model 544 Hydro??
Posted by mkirsch on August 21, 2008 at 11:27:57 from (64.80.110.50):
In Reply to: Differential Lock on 1969 Model 544 Hydro?? posted by Indy on August 21, 2008 at 09:54:15:
The only reason it would work like that is if something is wrong with your differential. Worn shafts or bushings causing misalignment and binding of gears...
Are you SURE it's actually locking, or are both wheels spinning due to lack of traction?
I suspect that:
1. It's muddy and/or otherwise slippery.
2. One wheel loses traction.
3. You step on the brake to get the other wheel to spin.
4. The other wheel spins and loses traction too.
5. You release the brake.
6. Both wheels spin because neither has any traction.
