Re: 1466 transmisson
Posted by Kevin Meier on August 21, 2008 at 16:24:13 from (64.71.85.247):
In Reply to: 1466 transmisson posted by cobra1379 on August 21, 2008 at 14:29:41:
Before you put the mcv back on did you replace the sump check plug? Is the mcv set correctly? Is you hydraullic pump working properly? A few different things can cause the hydraullics to drop. As far as the gear you have a gear in backwards or one of the shift parts aren"t connected right. Do you have gauges to check your hydraullic pressures?
Good luck
Kevin
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
