Re: Farmall H engine bearings… removed rod caps
Posted by Bob S. on August 21, 2008 at 17:03:36 from (68.113.237.237):
In Reply to: Re: Farmall H engine bearings… removed rod caps posted by Joe Henry on August 21, 2008 at 15:56:21:
Hey, if you want to gamble a few bucks for bearings, gasket and oil, give it a shot. Dress up the crank journals real good with very fine emery paper ( comes on a roll, about 1 inch wide, easy to work with )I dont know what caused that thrust surface to wear like that, maybe low on oil, but I would give it a try, you might get lucky and if not you wont be much worse off than you are now.In the old days they did lots of odd repairs, shim stock under bearings etc, sometimes it even worked. good luck
Bob S.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
