Posted by CNKS on August 21, 2008 at 17:51:58 from (216.144.104.128):
In Reply to: Old M still won't tun posted by Bob in E.Texas on August 21, 2008 at 17:37:37:
I don't remember your post specifically as there are hundreds like yours. But, your symptoms indicate a classic fuel flow problem. Could be crud in the tank that plugs the outlet, sediment bowl or carb. There is a screen in the fitting that the gas line screws into -- check that. Run a wire inside of the tank through the outlet. If all the preceding is clean, disassemble the carb, soak it in carb cleaner overnight, blow out passages with compressed air (each inlet in the carb has an outlet somewhere, make sure the air is going through) put a quality kit in and reassemble. I think your tractor dealership person is used to working on tractors in good condition, not ones that have sitting around little used for 30-50 years.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
