Re: Farmall H engine bearings… removed rod caps
Posted by P and R Pete on August 21, 2008 at 18:00:49 from (207.7.181.174):
In Reply to: Re: Farmall H engine bearings… removed rod caps posted by Scott Rukke on August 21, 2008 at 17:08:44:
I"ll agree with Scott, but I don"t know that Bob S. doesn"t have it right too. Crankshafts on a tractor aren"t hard to get at. However, as I understand it, if your fingernail can feel ANYthing while drawing it across a journal, it should be turned.
Ain"t cheap, though. The "grind/polish/finish" on my SA crank cost $130, beyond the cost for magnafluxing and checking runout ($24), and some $80 for new bearings.
And that was on the replacement crank. The original one that was in my engine turned out, on magnafluxing, to have a crack!
Maybe it all comes down to money. Nothing wrong with that either, if you need it back in the field. Nobody will guarantee how long before it needs it again, but the top RPM aren"t in the Nascar-range either.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
