Re: Farmall H engine bearings… removed rod caps
Posted by glennster on August 21, 2008 at 18:40:34 from (68.60.242.156):
In Reply to: Re: Farmall H engine bearings… removed rod caps posted by Joe Henry on August 21, 2008 at 15:56:21:
what end of the thrust bearing went? the side on the front of the motor or the side toward the rear? whatever is going on , i suspect something is pushing the crankshaft. if it was the rear of the thrustbearing, could be coming from the clutch or input shaft of the trans. i've seen this happen if too much grease was put on a pilot bearing and the shaft constantly pushes the crankshaft forward, it will wipe out a thrust bearing. i would split the tractor and pull the crank.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
