Re: 1466 transmisson
Posted by Owen Aaland on August 21, 2008 at 18:54:06 from (65.161.86.52):
In Reply to: 1466 transmisson posted by cobra1379 on August 21, 2008 at 14:29:41:
Are you sure you have two different speeds when selecting first or second gear? I think you will find that there is a problem with the 1-2 shift fork or linkage under the shift cover. Is the roller missing from the arm that moves the shift fork? A missing roller may allow the 1-2 gear to remain partly engaged when you shift to 3 or 4.
The steering and brake problem most likely is in the MCV. The pump may be weak but it must work some because you have steering and brakes before the dump valve is activated.
