Re: Bull Gear M
Posted by Roger46 on August 21, 2008 at 19:02:05 from (69.58.159.111):
In Reply to: Bull Gear M posted by moonlite 37 on August 20, 2008 at 03:29:18:
If you have a tooth out on the bull gear you also may have damage on the pinion gear. Years ago my dad was driving the Super H plowing and all of a sudden the tractor stopped. For some reason he put the tractor in low gear and let out the clutch at which point he heard a crunch and then a clicking sound every time the wheel went around. He had knocked out a tooth in the bull gear and also severely damaged one of the teeth on the pinion gear. Turns out a bearing had gone out and one of the cracked balls got between the teeth. So it turned out to be an expensive repair. I think if you run it that way even under light load you are asking for trouble as it is likely that you may knock out more teeth. Also as a side note, the last time I tried to get an M axle housing gasket they weren't available and I had to make one (not an easy gasket to make). Roger
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
