Re: Farmall H engine bearings… removed rod caps
Posted by Steven f/AZ on August 22, 2008 at 07:07:32 from (216.67.213.217):
In Reply to: Re: Farmall H engine bearings… removed rod caps posted by Joe Henry on August 21, 2008 at 15:56:21:
I would like to see a new set of bearings put in and run it ---- it's not my money or my tractor and I'm interested in seeing what happens!
Thrust bearing will wear on the front surface from normal use of pushing the clutch in - if it was used for certain chores, the clutch may have been pushed more than it was out... and running low on oil will wipe out bearings quick...
I think these old low RPM engines can be pretty forgiving... if you try it and it still knocks, you're not out much $$$
