Re: valve adjustment H
Posted by Janicholson on August 22, 2008 at 13:28:52 from (199.17.6.122):
In Reply to: valve adjustment H posted by poorfarmall1 on August 22, 2008 at 13:00:35:
THat is the cold (approximate) seting they will not make apreciable noise till they get to .030" or so cold. As they heat, the stems become hotter than the engine castings, and the pushrode lengthen as well. The clearance then tightens to the running (hot) spec. Thus it is best to set them hot, but they are close now. The cam has a tiny ramp area designed into the profile that takes up the clearance gently reducing noise to near nothing. If the clearance is so wide that this ramp slaps the clearance shut, there is noise. JimN
