Re: low oil pressure in 1939 farmall H
Posted by Janicholson on August 22, 2008 at 17:47:29 from (66.173.50.130):
In Reply to: Re: low oil pressure in 1939 farmall H posted by Rich ORourke on August 22, 2008 at 16:00:40:
Two real issues are now at hand.
An alternator needs a reference voltage to operate without making extreme volts (like 18 or more)
It must have a battery.
The coil is overheating. with a battery in it, it needs either a 12v coil (with the neg terminal to the distributor), or a ballast resistor in the lead going to the coil from the key/switch.
The following info is the main event. JimN
