Re: OT Cutting down combine fan blades
Posted by Ron-MO on August 22, 2008 at 19:03:06 from (98.20.225.167):
In Reply to: OT Cutting down combine fan blades posted by riverbend on August 22, 2008 at 18:09:00:
If you are like me, and do not have a plasma cutter, and am just a little thrifty, i would simply lay it on top, scribe a line, and cut with a 4 inch angle grinder. A little final cleanup and drill new holes and you should be good to go. Plasma cutter is the way to go if you have access though.
