Re: low oil pressure in 1939 farmall H
Posted by Rich ORourke on August 22, 2008 at 22:35:15 from (68.163.13.135):
In Reply to: Re: low oil pressure in 1939 farmall H posted by Andy Motteberg on August 22, 2008 at 19:42:50:
thanks for the tips, what weight is that oil you use, I have some 20W40 from my
dads old truck that is not opened yet, I wonder if I could use it in the farmall H? I noticed that the 12 volt conversion coil does get hot when the tractor is running. I thought if I put a heat shield on it, but it might be getting hot from the electricity running through it.
