Re: low oil pressure in 1939 farmall H
Posted by rich orourke on August 22, 2008 at 22:41:09 from (68.163.13.135):
In Reply to: Re: low oil pressure in 1939 farmall H posted by Steven f/AZ on August 22, 2008 at 08:46:36:
thanks, I just took apart the bottom of the oil pump and will check it for flatness tomorrow. I took off the screen at the end of the pump intake and cleaned it with Tylex soap and scum cleaner, it is an excellent degreaser and it is cheap and biodegradable and water based. I used a quart sized ultrasonic cleaner from Harbor freight, it really got all the sludge out of it well. Is the relief spring under the pllug on the side of the pump, or is it the spring with the clinder on the end of it that falls out when you take the bottom of the pump off?
