There are two, one in the plunger assy. and one in the primary pump. The one in the pump is the usual culprit. Take the primary pump off the back of the main pump, it comes off with two bolts. If you are familiar with gear pumps it"s pretty self-explanatory, or my e-mail if open if you have questions.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
