Re: Farmall A Hydraulics
Posted by Janicholson on August 23, 2008 at 09:27:14 from (66.173.50.60):
In Reply to: Farmall A Hydraulics posted by old A on August 23, 2008 at 04:10:53:
As Teddy indicates, you will need to determine if there is a cover plate for the pump on your block. If not, it will not work. Look at them both. JimN
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
