Posted by ih560 on August 23, 2008 at 10:46:21 from (204.118.68.33):
In Reply to: Farmall A Hydraulics posted by old A on August 23, 2008 at 04:10:53:
The super A block has provisions for a hydraulic pump where a Farmall A block does not. If you look below the magneto or distributor you will see a place on a Super A block that has a mounting location for the pump that you will not see on an A block.
In other words unless your A has a Newer model engine in it, then you are not going to be able to use the hydraulic pump from a Super A.
And even if your tractor does has the super A equivalent engine, I would doubt that you would have the correct clutch housing to use the rest of the Super A hydraulics, So you would have to make your own reservoir and control system, which isn't all that much trouble but you are in for a lot of work and money buying valves and cylinders.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
