Posted by El Toro on August 23, 2008 at 16:34:06 from (64.12.116.73):
In Reply to: h Won't start wnen hot posted by new h owner needs help on August 23, 2008 at 14:50:54:
Could be a weak coil too. When it quits check for fire to the plugs asap before the coil can cool. Do as Dave suggested since that won't cost as much as replacing the coil. Hal
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
