Re: Farmall M...some charge, but not enough
Posted by El Toro on August 23, 2008 at 16:41:24 from (64.12.116.73):
In Reply to: Farmall M...some charge, but not enough posted by dubv on August 23, 2008 at 13:11:14:
Take a volt meter and check the charging voltage across the battery terminals. On a 6 volt system should be around 7-7.2 volts with the engine at 1/2 to 3/4 throttle. Hal
PS: If your battery is fully charged it may not show much of a charge. The rate of charge will drop as the battery is charged. Not showing a charge at idle is probably normal.
