Re: Farmall A Hydraulics
Posted by Hugh MacKay on August 23, 2008 at 17:45:19 from (209.226.106.177):
In Reply to: Farmall A Hydraulics posted by old A on August 23, 2008 at 04:10:53:
ols A: Look both tractors over closely. Super A torque tube is flat on top under the touch control unit. Then as the others mentioned unless the engine is drilled for a hydraulic pump, you will need the SA block. About the only way your A engine would have provission for the pump is if the block were 1947 or later. Block part numbers 2510869 R1 or 354898 R1 from SA, C or SC are drilled, 6342DH is not, that being the block used in all A or B tractoers.
You them over an compare, you'll soon see what I'm talking about.
