Re: 49 Cub wiring
Posted by Gale Roberts on August 23, 2008 at 19:30:39 from (64.12.116.73):
In Reply to: Re: 49 Cub wiring posted by Michael Adams on August 23, 2008 at 11:08:12:
The letter "L"stands for low charge which means with the switch in that position the resistor is in line from generator "F" to ground and generator charges a lower amount. The letter "H" stands for high charge which means in that position the "F" wire from generator goes straight to ground which makes the generator charge at maximum. The letter "D" is for headlights on dim and the letter "B" is for headlights on bright.......Gale
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
