Re: Cub PTO pulling out the back of tractor
Posted by john *.?-!.* cub owner on August 23, 2008 at 19:57:52 from (69.179.147.32):
In Reply to: Cub PTO pulling out the back of tractor posted by Doug Zimmerman on August 23, 2008 at 14:44:49:
There were 2 versions of the pto/shaft bearing. later ones had a snap ring on the shaft to keep the shaft form sliding out through the bearing. earlier ones had the shaft staked ( center punched ) to raise high spots to keep it form slipping out.
