Re: H hydrolic pump mid mount mower
Posted by Janicholson on August 24, 2008 at 06:52:22 from (66.173.50.32):
In Reply to: Re: H hydrolic pump mid mount mower posted by poorfarmall1 on August 24, 2008 at 06:35:11:
They (on a good day) put out 750 to 800psi. If you put a gauge on it and it is much less, I would say checking the relief valve might be in order. Or a rebuild might be needed. If the gears and case are worn, they are not able to be repaired.
If you are using Hytran or = fluid, I would use thicker viscosity oil (30 wt non detergent will be good)
If the pressure is up there, a bigger diameter cylinder will work. adding 20% to the diameter will do it.
JimN
