Re: sickle mower
Posted by Steven f/AZ on August 24, 2008 at 08:52:46 from (24.156.15.203):
In Reply to: sickle mower posted by Tugb on August 24, 2008 at 06:49:01:
I'm going to assume your tractor is a Farmall 130...
There are several options for a sickle mower...
You can have a pull type, semi mounted, or fully mounted. I have all three and can say that I definitaly prefer the fully mounted. Then there is the choice between a pitman mower (stick that moves the sickle back and forth) or a pitmanless balanced head mower (modern type). There are many model numbers for each type of mower, as well.
Here are some examples of what I have:
100 trailer mower (newer model is the 1100):
third party image
Video of trailer-type 100 mower: http://www.youtube.com/watch?v=0mmi7Yq1Al4
120 semi-mounted:
third party image
1110 fully mounted:
third party image
Video of 1110 mower: http://www.youtube.com/watch?v=DWLEffYTPBk
Your 130 will have plenty of power for a 5', 6', 7', or 9' bar on any type of mower. If you are mowing very heavy hay, the 9' bar might have enough of a draft to pull the tractor slightly sideways...
If you have some specific questions, I have owner's manuals for the three mowers I own and a shop manual that covers just about every one of the IH balanced-head mowers... and a Blue Ribbon service manual for the balanced head itself. :)
This post was edited by Steven f/AZ at 08:53:24 08/24/08.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
